Ana içeriğe geç
Kyocera Hydro Vibe Headphone Jack Replacement
Neye ihtiyacın var
  1. Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 1. Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 2. Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 3.
    • Pop the back plate off by using your hands or a spudger.
  2. Kyocera Hydro Vibe Headphone Jack Replacement: adım 2, 3 resimden 1. Kyocera Hydro Vibe Headphone Jack Replacement: adım 2, 3 resimden 2. Kyocera Hydro Vibe Headphone Jack Replacement: adım 2, 3 resimden 3.
    • Remove the trim from the phone by carefully prying it away using your hands.
  3. Kyocera Hydro Vibe Headphone Jack Replacement: adım 3, 2 resimden 1. Kyocera Hydro Vibe Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
  4. Kyocera Hydro Vibe Headphone Jack Replacement: adım 4, 3 resimden 1. Kyocera Hydro Vibe Headphone Jack Replacement: adım 4, 3 resimden 2. Kyocera Hydro Vibe Headphone Jack Replacement: adım 4, 3 resimden 3.
    • Remove the battery by popping it out of the phone by using your hands or the spudger to pry it up out of the case.
  5. Kyocera Hydro Vibe Headphone Jack Replacement: adım 5, 2 resimden 1. Kyocera Hydro Vibe Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Remove the inner plate from the phone using the spudger or your fingers.
  6. Kyocera Hydro Vibe Headphone Jack Replacement: adım 6, 3 resimden 1. Kyocera Hydro Vibe Headphone Jack Replacement: adım 6, 3 resimden 2. Kyocera Hydro Vibe Headphone Jack Replacement: adım 6, 3 resimden 3.
    • Remove the headphone jack using the spudger to push down on the jack to dislodge it from the phone.
    • Once the headphone jack is dislodged, you can disconnect the ribbon cable by carefully pulling it out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katherine Pfeiffer
154 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G6, Harley Fall 2018 IUPUI, Team S3-G6, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S3G6
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 229
