Ana içeriğe geç
Kyocera Hydro Vibe Internal Speaker Replacement
Neye ihtiyacın var
  1. Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: adım 1, 3 resimden 1. Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: adım 1, 3 resimden 2. Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: adım 1, 3 resimden 3.
    • Remove the back plate of the device by popping it off with your fingernail or a spudger.
  2. Kyocera Hydro Vibe Internal Speaker Replacement: adım 2, 2 resimden 1. Kyocera Hydro Vibe Internal Speaker Replacement: adım 2, 2 resimden 2.
    • Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
  3. Kyocera Hydro Vibe Internal Speaker Replacement: adım 3, 3 resimden 1. Kyocera Hydro Vibe Internal Speaker Replacement: adım 3, 3 resimden 2. Kyocera Hydro Vibe Internal Speaker Replacement: adım 3, 3 resimden 3.
    • Remove the trim around the outside of the device by peeling it off with your hands.
  4. Kyocera Hydro Vibe Internal Speaker Replacement: adım 4, 3 resimden 1. Kyocera Hydro Vibe Internal Speaker Replacement: adım 4, 3 resimden 2. Kyocera Hydro Vibe Internal Speaker Replacement: adım 4, 3 resimden 3.
    • Remove battery using the spudger or your fingernails to pry the battery up out of the case.
  5. Kyocera Hydro Vibe Internal Speaker Replacement: adım 5, 2 resimden 1. Kyocera Hydro Vibe Internal Speaker Replacement: adım 5, 2 resimden 2.
    • Now remove the rear frame, exposing the speaker. To remove the frame you can use the Spudger tool from the iFixit Tool kit or your hands.
  6. Kyocera Hydro Vibe Internal Speaker Replacement: adım 6, 3 resimden 1. Kyocera Hydro Vibe Internal Speaker Replacement: adım 6, 3 resimden 2. Kyocera Hydro Vibe Internal Speaker Replacement: adım 6, 3 resimden 3.
    • Remove the speaker from its location on the back frame using a spudger.
Sonuç
Ben Lange
139 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G6, Harley Fall 2018 IUPUI, Team S3-G6, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S3G6
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 194
