Ana içeriğe geç
Kyocera Hydro Vibe Trim Replacement
Neye ihtiyacın var
  1. Kyocera Hydro Vibe Trim Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Trim Replacement: adım 2, 3 resimden 1. Kyocera Hydro Vibe Trim Replacement: adım 2, 3 resimden 2. Kyocera Hydro Vibe Trim Replacement: adım 2, 3 resimden 3.
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Trim Replacement, Trim: adım 3, 1 resimden 1.
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Trim Replacement: adım 4, 2 resimden 1. Kyocera Hydro Vibe Trim Replacement: adım 4, 2 resimden 2.
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Trim Replacement: adım 5, 1 resimden 1.
    • The trim is flimsy.
    • This is what the trim will look like once removed.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 694
