Giriş
Information to replace the screen of your Kyocera Oystr.
Neye ihtiyacın var
Make sure the phone is turned off before disassembly.
Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
Remove the battery from the casing. This is simply a precaution.
Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
Lift the plastic cover of the phone screen upwards with a plastic opening tool.
Remove the two screws from the metal cover.
Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
Use your fingernail to detach the ribbon connecting the board to the screen.
Remove the damaged screen from the device.
Follow these steps in reverse order to replace Kyocera Oystr’s screen.
2 Yorum
My screen goes blank for days, then shows. maybe for minutes of seconds. Do I need to replace the screen, or is there a control I can try to bring back the display? The phone is charged and rings. Yours is a wonderful website. Thank you.
Martha Carnahan mpc@netsync.net
My screen goes blank for days, then appears, but only for minutes or seconds before it goes blank again. Do I need to replace the screen, or do you know if there a command which would solve the problem? The phone is charged and rings.
