Ana içeriğe geç
Kyocera QCP-2035 Microphone Replacement
Neye ihtiyacın var
  1. Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: adım 1, 3 resimden 1. Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: adım 1, 3 resimden 2. Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: adım 1, 3 resimden 3.
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Microphone Replacement: adım 2, 3 resimden 1. Kyocera QCP-2035 Microphone Replacement: adım 2, 3 resimden 2. Kyocera QCP-2035 Microphone Replacement: adım 2, 3 resimden 3.
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
  3. Kyocera QCP-2035 Microphone Replacement: adım 3, 3 resimden 1. Kyocera QCP-2035 Microphone Replacement: adım 3, 3 resimden 2. Kyocera QCP-2035 Microphone Replacement: adım 3, 3 resimden 3.
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
  4. Kyocera QCP-2035 Microphone Replacement: adım 4, 3 resimden 1. Kyocera QCP-2035 Microphone Replacement: adım 4, 3 resimden 2. Kyocera QCP-2035 Microphone Replacement: adım 4, 3 resimden 3.
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
  5. Kyocera QCP-2035 Microphone Replacement, Microphone: adım 5, 3 resimden 1. Kyocera QCP-2035 Microphone Replacement, Microphone: adım 5, 3 resimden 2. Kyocera QCP-2035 Microphone Replacement, Microphone: adım 5, 3 resimden 3.
    • Locate the microphone at the bottom left corner of the phone.
    • using tweezers, Lift the microphone straight out of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
cove
116 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 5-3, Brown Winter 2015 USF Tampa, Team 5-3, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 223
