Giriş
You will learn how to disassemble the phone and remove the speaker safely.
Neye ihtiyacın var
When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
In 5 mm it will stop sliding.
Locate the speaker at the top of the phone right above the screen.
Using a spudger or pair of tweezers, gently rock and pry from between the speaker and the main board.
Bir başkası bu kılavuzu tamamladı.
