Giriş
If battery power is draining too quickly, or if it is unable to hold a charge altogether, it's time to replace the battery. The task is simple and straightforward, with minimal tools required. Follow this guide to replace the battery for your Kyocera Zio M6000.
Neye ihtiyacın var
Press down on the back of the phone, applying moderate pressure.
Slide the back casing down to separate it.
Bir başkası bu kılavuzu tamamladı.
