Ana içeriğe geç
Kyocera Zio M6000 Digitizer Replacement
Neye ihtiyacın var
  1. Kyocera Zio M6000 Digitizer Replacement, Battery: adım 1, 2 resimden 1. Kyocera Zio M6000 Digitizer Replacement, Battery: adım 1, 2 resimden 2.
    • Press down on the back of the phone, applying moderate pressure.
    • Slide the back casing down to separate it.
    FixBot'a Sor
  2. Kyocera Zio M6000 Digitizer Replacement: adım 2, 2 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 2, 2 resimden 2.
    • Remove the back casing to expose the battery.
    • Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
    FixBot'a Sor
  3. Kyocera Zio M6000 Digitizer Replacement, Motherboard: adım 3, 2 resimden 1. Kyocera Zio M6000 Digitizer Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the six 3.18 mm screws using a Phillips 00 screwdriver.
    FixBot'a Sor
  4. Kyocera Zio M6000 Digitizer Replacement: adım 4, 2 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 4, 2 resimden 2.
    • Insert the flat end of the spudger between the front and back panels, and pry it apart by running the spudger along the side to further separate them.
    • Go all the way around, prying as you go, until the back casing completely separates from the rest of the phone.
    FixBot'a Sor
  5. Kyocera Zio M6000 Digitizer Replacement: adım 5, 3 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 5, 3 resimden 2. Kyocera Zio M6000 Digitizer Replacement: adım 5, 3 resimden 3.
    • Unclip the two flex cables -- a small one located on the left side on the lower half of the motherboard, and a longer one on the right side, higher up.
    FixBot'a Sor
  6. Kyocera Zio M6000 Digitizer Replacement: adım 6, 3 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 6, 3 resimden 2. Kyocera Zio M6000 Digitizer Replacement: adım 6, 3 resimden 3.
    • Pry out the earpiece speaker using the spudger.
    • Pry out the vibration motor using the spudger.
    FixBot'a Sor
  7. Kyocera Zio M6000 Digitizer Replacement: adım 7, 2 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 7, 2 resimden 2.
    • Place the flat end of the spudger underneath the digitizer connector and pry it up to disconnect it.
    FixBot'a Sor
  8. Kyocera Zio M6000 Digitizer Replacement: adım 8, 3 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 8, 3 resimden 2. Kyocera Zio M6000 Digitizer Replacement: adım 8, 3 resimden 3.
    • Remove the sticker to uncover the screws underneath.
    • Remove the six 1.59 mm screws using a Phillips 00 screwdriver.
    FixBot'a Sor
  9. Kyocera Zio M6000 Digitizer Replacement: adım 9, 3 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 9, 3 resimden 2. Kyocera Zio M6000 Digitizer Replacement: adım 9, 3 resimden 3.
    • Lift the bottom portion of the motherboard away from the front panel.
    • Do not forcefully pull the components apart as there is another connector on the underside of the motherboard attaching it to the panel.
    • Insert the flat end of the spudger in between the panel and motherboard to unfasten the connector.
    FixBot'a Sor
  10. Kyocera Zio M6000 Digitizer Replacement, Digitizer: adım 10, 3 resimden 1. Kyocera Zio M6000 Digitizer Replacement, Digitizer: adım 10, 3 resimden 2. Kyocera Zio M6000 Digitizer Replacement, Digitizer: adım 10, 3 resimden 3.
    • Remove the two rubber pieces from the ends of the panel.
    FixBot'a Sor
  11. Kyocera Zio M6000 Digitizer Replacement: adım 11, 3 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 11, 3 resimden 2. Kyocera Zio M6000 Digitizer Replacement: adım 11, 3 resimden 3.
    • Remove the red Power button and green Talk button from the bottom of the casing.
    • Remove the trackball, also at the bottom of the casing.
    FixBot'a Sor
  12. Kyocera Zio M6000 Digitizer Replacement: adım 12, 3 resimden 1. Kyocera Zio M6000 Digitizer Replacement: adım 12, 3 resimden 2. Kyocera Zio M6000 Digitizer Replacement: adım 12, 3 resimden 3.
    • Pry the bottom edge of the bezel with the flat end of the spudger.
    • Carefully run the spudger up the sides until the digitizer is free.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Scott Nguyen
522 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 41
Her zaman: 621
