Ana içeriğe geç
Kyvol Cybovac L20 Brush Roller Motor Replacement
Neye ihtiyacın var
  1. Kyvol Cybovac L20 Brush Roller Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Begin with the device laying on a flat surface with the power button facing up.
  2. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 2, 2 resimden 1. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 2, 2 resimden 2.
    • Remove both of the side brushes.
  3. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
    • Remove the battery panel.
  4. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 4, 2 resimden 1. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 4, 2 resimden 2.
    • Slightly lift the battery out of the compartment.
    • Disconnect the battery connector.
    • Completely remove the battery.
  5. Kyvol Cybovac L20 Brush Roller Motor Replacement, Brush Roller Motor: adım 5, 1 resimden 1.
    • Remove the dust bin from the underside of the unit.
  6. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 6, 2 resimden 1. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 6, 2 resimden 2.
    • Press in on the two clips holding the brush roller housing in place and remove the brush roller cover.
  7. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 7, 1 resimden 1.
    • Remove the brush roller.
  8. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 8, 1 resimden 1.
    • Remove the eight 12 mm Phillips screws from the underside of the unit.
  9. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 9, 3 resimden 1. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 9, 3 resimden 2. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 9, 3 resimden 3.
    • Slightly lift the bottom of the unit from the top housing, with care not to pull or damage the connections between the top case and motherboard.
    • Disconnect the three motherboard connections that connect the top case and motherboard.
  10. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 10, 1 resimden 1.
    • Remove the two 5.8 mm Phillips screws holding dustpan sensor board in place.
    • Move the sensor to the side.
  11. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 11, 2 resimden 1. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 11, 2 resimden 2.
    • Remove the three 8 mm Phillips screws that secure the motor housing in place.
  12. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 12, 2 resimden 1. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 12, 2 resimden 2.
    • Remove the two 7.4 mm Phillips screws from the belt assembly housing cover.
    • Remove the cover.
  13. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 13, 1 resimden 1.
    • Slip off the belt and pulley from the inside of the motor housing.
  14. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 14, 2 resimden 1. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 14, 2 resimden 2.
    • Remove the two 4.5 mm Phillips screws that secure the motor to the pully assembly housing.
    • Separate the motor from the housing.
  15. Kyvol Cybovac L20 Brush Roller Motor Replacement: adım 15, 1 resimden 1.
    • Grip the white motor motherboard connect and pull it directly up and out of its port.
    • Remove the motor.
Sonuç
Brad
397 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Spring 2024 IUPUI, Team 1-1, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 38
