Ana içeriğe geç
Kyvol Cybovac L20 Sensor Replacement
Neye ihtiyacın var
  1. Kyvol Cybovac L20 Sensor Replacement, Battery: adım 1, 1 resimden 1.
    • Begin with the device laying on a flat surface with the power button facing up.
  2. Kyvol Cybovac L20 Sensor Replacement: adım 2, 2 resimden 1. Kyvol Cybovac L20 Sensor Replacement: adım 2, 2 resimden 2.
    • Remove both of the side brushes.
  3. Kyvol Cybovac L20 Sensor Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
    • Remove the battery panel.
  4. Kyvol Cybovac L20 Sensor Replacement: adım 4, 2 resimden 1. Kyvol Cybovac L20 Sensor Replacement: adım 4, 2 resimden 2.
    • Slightly lift the battery out of the compartment.
    • Disconnect the battery connector.
    • Completely remove the battery.
  5. Kyvol Cybovac L20 Sensor Replacement, Sensor: adım 5, 1 resimden 1.
    • Remove the eight 12.2 mm Phillips screws.
  6. Kyvol Cybovac L20 Sensor Replacement: adım 6, 3 resimden 1. Kyvol Cybovac L20 Sensor Replacement: adım 6, 3 resimden 2. Kyvol Cybovac L20 Sensor Replacement: adım 6, 3 resimden 3.
    • Lift the body away from the base and disconnect all connectors between the two halves.
  7. Kyvol Cybovac L20 Sensor Replacement: adım 7, 1 resimden 1.
    • Remove the two 8 mm Phillips screws that secure the sensor.
  8. Kyvol Cybovac L20 Sensor Replacement: adım 8, 2 resimden 1. Kyvol Cybovac L20 Sensor Replacement: adım 8, 2 resimden 2.
    • Use a spudger or your fingernails to gently walk the white connector directly out of its port.
    • Remove the sensor.
Sonuç
Brad
397 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Spring 2024 IUPUI, Team 1-1, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 53
