Ana içeriğe geç
LCD LG 37LF65 Capacitor replacement
Neye ihtiyacın var
  1. LCD LG 37LF65 Capacitor replacement, Open the case: adım 1, 1 resimden 1.
    • Power off and unplug your device before starting this repair.
    • Open the case carefully while loosing the marked srews.
  2. LCD LG 37LF65 Capacitor replacement, Replace the capacitors: adım 2, 1 resimden 1.
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  3. LCD LG 37LF65 Capacitor replacement, Testing capacitors: adım 3, 1 resimden 1.
    • If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
Sonuç
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
9 farklı kişi bu kılavuzu tamamladı.
eugl18
561 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 13,457
