Ana içeriğe geç
LCD Replacement
  1. LCD Replacement, Rear Cover: adım 1, 1 resimden 1.
    • First ensure your laptop is turned off and check if you have the necessary tools
    FixBot'a Sor
    Yorum Ekle
  2. LCD Replacement: adım 2, 2 resimden 1. LCD Replacement: adım 2, 2 resimden 2.
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
    FixBot'a Sor
    Yorum Ekle
  3. LCD Replacement: adım 3, 3 resimden 1. LCD Replacement: adım 3, 3 resimden 2. LCD Replacement: adım 3, 3 resimden 3.
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
    FixBot'a Sor
    Yorum Ekle
  4. LCD Replacement: adım 4, 1 resimden 1.
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
    FixBot'a Sor
    Yorum Ekle
  5. LCD Replacement: adım 5, 3 resimden 1. LCD Replacement: adım 5, 3 resimden 2. LCD Replacement: adım 5, 3 resimden 3.
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
    FixBot'a Sor
    Yorum Ekle
  6. LCD Replacement: adım 6, 1 resimden 1.
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
    FixBot'a Sor
    Yorum Ekle
    • Insert instructions here.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow the previous steps in inverse order.
Bu çevirmenlere özel teşekkürler:
pt en
100%
David dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Nelson Oliveira
741 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 52
Her zaman: 453
