Ana içeriğe geç
LCD X2gen Display disassembly
Neye ihtiyacın var
  1. LCD X2gen Display disassembly, LCD X2gen Display disassembly: adım 1, 1 resimden 1.
    • X2gen 22 lcd Screen repair guide
  2. LCD X2gen Display disassembly: adım 2, 1 resimden 1.
    • Power board displaying the capacitors to be replaced
  3. LCD X2gen Display disassembly: adım 3, 1 resimden 1.
    • Display viewed laying face down on the working table (my dining table)
    • Remove the 6 screws. 4 on the corners and 2 middle bottom.
  4. LCD X2gen Display disassembly: adım 4, 1 resimden 1.
    • Remove front bezel by lifting softly starting from the middle and moving out to the corners.
  5. LCD X2gen Display disassembly: adım 5, 1 resimden 1.
    • Top middle
  6. LCD X2gen Display disassembly: adım 6, 1 resimden 1.
    • Front bezel removed.
    • Observe: the control board, bottom right.
    • exposed screws on both sides (4 left, 4 right) holding the LCD to the back cover.
  7. LCD X2gen Display disassembly: adım 7, 1 resimden 1.
    • Prepare to remove the 4 screws on each side to lift the LCD. Do not try to remove it after unscrewing the 8 screws. There are cables connected on the back.
    • This pic shows the right side
  8. LCD X2gen Display disassembly: adım 8, 1 resimden 1.
    • This pic shows the left side
  9. LCD X2gen Display disassembly: adım 9, 2 resimden 1. LCD X2gen Display disassembly: adım 9, 2 resimden 2.
    • Lift carefully about 2 inch to expose the back light connections, 2 pink and 2 white.
    • Slide the monitor to the left about 3-4 inch. to have access to the connections.
  10. LCD X2gen Display disassembly: adım 10, 1 resimden 1.
    • Carefully, unplug both connectors
  11. LCD X2gen Display disassembly: adım 11, 2 resimden 1. LCD X2gen Display disassembly: adım 11, 2 resimden 2.
    • After removing the connectors, slide it about 3-5 inches to the right to have access to the data connector and ground
  12. LCD X2gen Display disassembly: adım 12, 1 resimden 1.
    • Remove the data connector and ground.
    • Lift display. Is now completely free
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Aleks
201 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 1,085
