Ana içeriğe geç
LG 1010 Front Cover Replacement
Neye ihtiyacın var
  1. LG 1010 Front Cover Replacement, Front  Cover: adım 1, 2 resimden 1. LG 1010 Front Cover Replacement, Front  Cover: adım 1, 2 resimden 2.
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  2. LG 1010 Front Cover Replacement: adım 2, 1 resimden 1.
    • Remove two screws using a Torx T6 screwdriver.
  3. LG 1010 Front Cover Replacement: adım 3, 2 resimden 1. LG 1010 Front Cover Replacement: adım 3, 2 resimden 2.
    • Pry off the screen front cover with a small flathead screwdriver.
  4. LG 1010 Front Cover Replacement: adım 4, 1 resimden 1.
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  5. LG 1010 Front Cover Replacement: adım 5, 1 resimden 1.
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  6. LG 1010 Front Cover Replacement: adım 6, 1 resimden 1.
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Schmidt
97 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G25
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,156
