Ana içeriğe geç
LG 1010 Keypad Replacement
Neye ihtiyacın var
  1. LG 1010 Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the cell phone and place face down on a flat surface.
    FixBot'a Sor
    Yorum Ekle
  2. LG 1010 Keypad Replacement: adım 2, 2 resimden 1. LG 1010 Keypad Replacement: adım 2, 2 resimden 2.
    • While sliding the gray tab up, lift battery up and away from the cell phone.
    FixBot'a Sor
    Yorum Ekle
  3. LG 1010 Keypad Replacement: adım 3, 3 resimden 1. LG 1010 Keypad Replacement: adım 3, 3 resimden 2. LG 1010 Keypad Replacement: adım 3, 3 resimden 3.
    • Remove battery and set aside.
    FixBot'a Sor
    Yorum Ekle
  4. LG 1010 Keypad Replacement, Antenna: adım 4, 1 resimden 1.
    • While holding cell phone firmly in one hand, unscrew and remove the antenna with the other hand.
    FixBot'a Sor
    Yorum Ekle
  5. LG 1010 Keypad Replacement: adım 5, 2 resimden 1. LG 1010 Keypad Replacement: adım 5, 2 resimden 2.
    • Pull the antenna housing (black tube) towards bottom of phone and remove.
    FixBot'a Sor
    Yorum Ekle
  6. LG 1010 Keypad Replacement, Back Cover: adım 6, 2 resimden 1. LG 1010 Keypad Replacement, Back Cover: adım 6, 2 resimden 2.
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. LG 1010 Keypad Replacement: adım 7, 2 resimden 1. LG 1010 Keypad Replacement: adım 7, 2 resimden 2.
    • Pull the back cover straight off the phone using your thumb and forefinger.
    FixBot'a Sor
    Yorum Ekle
  8. LG 1010 Keypad Replacement, Keypad: adım 8, 1 resimden 1.
    • Pry off circuit board with a flathead screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. LG 1010 Keypad Replacement: adım 9, 1 resimden 1.
    • Pull out flexible keypad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Install new keypad and reassemble following these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Nicholas Schmidt
97 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G25
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 1,298
