Ana içeriğe geç
LG 1010 LCD Screen Replacement
Neye ihtiyacın var
  1. LG 1010 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the cell phone and place face down on a flat surface.
  2. LG 1010 LCD Screen Replacement: adım 2, 2 resimden 1. LG 1010 LCD Screen Replacement: adım 2, 2 resimden 2.
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. LG 1010 LCD Screen Replacement: adım 3, 3 resimden 1. LG 1010 LCD Screen Replacement: adım 3, 3 resimden 2. LG 1010 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Remove battery and set aside.
  4. LG 1010 LCD Screen Replacement, Front  Cover: adım 4, 2 resimden 1. LG 1010 LCD Screen Replacement, Front  Cover: adım 4, 2 resimden 2.
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  5. LG 1010 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove two screws using a Torx T6 screwdriver.
  6. LG 1010 LCD Screen Replacement: adım 6, 2 resimden 1. LG 1010 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Pry off the screen front cover with a small flathead screwdriver.
  7. LG 1010 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  8. LG 1010 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  9. LG 1010 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
  10. LG 1010 LCD Screen Replacement, Back Cover: adım 10, 2 resimden 1. LG 1010 LCD Screen Replacement, Back Cover: adım 10, 2 resimden 2.
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  11. LG 1010 LCD Screen Replacement: adım 11, 2 resimden 1. LG 1010 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Pull the back cover straight off the phone using your thumb and forefinger.
  12. LG 1010 LCD Screen Replacement, Keypad: adım 12, 1 resimden 1.
    • Pry off circuit board with a flathead screwdriver.
  13. LG 1010 LCD Screen Replacement: adım 13, 1 resimden 1.
    • Pull out flexible keypad.
  14. LG 1010 LCD Screen Replacement, LCD Screen: adım 14, 1 resimden 1.
    • The phone should now look like the picture to the left.
  15. LG 1010 LCD Screen Replacement: adım 15, 2 resimden 1. LG 1010 LCD Screen Replacement: adım 15, 2 resimden 2.
    • Locate and detach the ribbon cable from circuit board.
  16. LG 1010 LCD Screen Replacement: adım 16, 2 resimden 1. LG 1010 LCD Screen Replacement: adım 16, 2 resimden 2.
    • Remove the LCD Screen from the phone case and replace with a new LCD screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicholas Schmidt
97 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G25
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 1,001
