Giriş
Before completing this replacement guide, it is important to unplug the device. This replacement guide will show how to replace the internal casing in the device.
Neye ihtiyacın var
Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
Sonuç
