Ana içeriğe geç
LG 305C Speaker Replacement
Neye ihtiyacın var
  1. LG 305C Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Speaker Replacement: adım 2, 1 resimden 1.
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Speaker Replacement, Internal Casing: adım 3, 1 resimden 1.
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  4. LG 305C Speaker Replacement: adım 4, 1 resimden 1.
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  5. LG 305C Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  6. LG 305C Speaker Replacement: adım 6, 1 resimden 1.
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  7. LG 305C Speaker Replacement, Speaker: adım 7, 1 resimden 1.
    • Insert plastic opening tool under the plastic flap and lift the speaker out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joaquin Garcia
73 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S6-G1, Baechle Spring 2018 IUPUI, Team S6-G1, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S6G1
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 151
