Ana içeriğe geç
LG 32CS560 Power Supply Board Replacement
Neye ihtiyacın var
  1. LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: adım 1, 2 resimden 1. LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: adım 1, 2 resimden 2.
    • Lay the TV face down on a soft surface
    • Remove the base of the TV by unscrewing the 4 base screws.
    • There is no base on the picture, the position of the base is marked whit the red box.
  2. LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: adım 2, 2 resimden 1. LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: adım 2, 2 resimden 2.
    • Remove the 15 Phillips head screws on the back of the TV.
    • Carefully remove the black plastic back panel of the TV to expose the electronics inside
  3. LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: adım 3, 3 resimden 1. LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: adım 3, 3 resimden 2. LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: adım 3, 3 resimden 3.
    • Carefully disconnect the three wire bundles attached to the power supply.
    • Remove the four screws holding the power supply in place.
    • Now you can lift out the Power Supply Board.
    • If the black cylindrical component marked with yellow seems to have expanded or is leaking liquid or goo, then the power supply board is definitely bad.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Coyt Barringer
647 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Donnelly Fall 2014 USF Tampa, Team 1-3, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G3
1 Üye
1 Kılavuz yazıldı
Bir Yorum
preciso duma destas power bord como fazer para ter
brun mendes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 43
Son 30 gün: 167
Her zaman: 44,587
