Ana içeriğe geç
LG BP220 Disc Drive Replacement
Neye ihtiyacın var
    1. LG BP220 Disc Drive Replacement, Disc Drive: adım 1, 2 resimden 1. LG BP220 Disc Drive Replacement, Disc Drive: adım 1, 2 resimden 2.
      • Ensure the device is unplugged to prevent shocks.
      • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
      • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
      FixBot'a Sor
      Yorum Ekle
    2. LG BP220 Disc Drive Replacement: adım 2, 1 resimden 1.
      • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. LG BP220 Disc Drive Replacement: adım 3, 3 resimden 1. LG BP220 Disc Drive Replacement: adım 3, 3 resimden 2. LG BP220 Disc Drive Replacement: adım 3, 3 resimden 3.
      • Unhinge the tabs that attach the front panel to the unit:
      • Two tabs on the disc drive
      • Two tabs on the left and right side of the player
      • Be careful when handling these tabs. They are very fragile and can be easily broken.
      • Three tabs on the underside of the player
      • Pull panel away from case.
      • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
      FixBot'a Sor
      Yorum Ekle
    4. LG BP220 Disc Drive Replacement: adım 4, 2 resimden 1. LG BP220 Disc Drive Replacement: adım 4, 2 resimden 2.
      • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
      • With the front side facing you lift the front of disc drive and pull out to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Bart Quicho
520 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-1, Rose Winter 2015 UW Tacoma, Team 1-1, Rose Winter 2015 üyesi
UWT-ROSE-W15S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 9,587
