Ana içeriğe geç
LG CF360 Rear Speaker Replacement
Neye ihtiyacın var
  1. LG CF360 Rear Speaker Replacement, Battery: adım 1, 2 resimden 1. LG CF360 Rear Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Rear Speaker Replacement: adım 2, 1 resimden 1.
    • Lift and remove the battery.
  3. LG CF360 Rear Speaker Replacement, Back Cover: adım 3, 2 resimden 1. LG CF360 Rear Speaker Replacement, Back Cover: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Rear Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Rear Speaker Replacement: adım 5, 3 resimden 1. LG CF360 Rear Speaker Replacement: adım 5, 3 resimden 2. LG CF360 Rear Speaker Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Rear Speaker Replacement: adım 6, 1 resimden 1.
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Rear Speaker Replacement, Rear Speaker: adım 7, 1 resimden 1.
    • Use the plastic opening tool to pry the speaker cover off of the phone.
  8. LG CF360 Rear Speaker Replacement: adım 8, 1 resimden 1.
    • Use the plastic opening tool to pry the speaker out of the back cover.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Annie White
262 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-27, Amido Fall 2013 Cal Poly, Team 4-27, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G27
4 Üyeler
19 adet Kılavuz yazıldı
1Rehber Yorum
Where can I buy the replacement parts?
Sarah Birkett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 369
