Ana içeriğe geç
LG CG180 Display Replacement
Neye ihtiyacın var
  1. LG CG180 Display Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Display Replacement: adım 2, 1 resimden 1.
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Display Replacement: adım 3, 2 resimden 1. LG CG180 Display Replacement: adım 3, 2 resimden 2.
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Display Replacement: adım 4, 1 resimden 1.
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Display Replacement: adım 5, 1 resimden 1.
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Display Replacement, Hardshell Case: adım 6, 1 resimden 1.
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Display Replacement: adım 7, 1 resimden 1.
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Display Replacement: adım 8, 2 resimden 1. LG CG180 Display Replacement: adım 8, 2 resimden 2.
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Display Replacement: adım 9, 2 resimden 1. LG CG180 Display Replacement: adım 9, 2 resimden 2.
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Display Replacement: adım 10, 1 resimden 1.
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Display Replacement: adım 11, 1 resimden 1.
    • The hardshell case is separated from the rest of the phone.
  12. LG CG180 Display Replacement, Keypad: adım 12, 2 resimden 1. LG CG180 Display Replacement, Keypad: adım 12, 2 resimden 2.
    • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
  13. LG CG180 Display Replacement, Display: adım 13, 1 resimden 1.
    • Place the circuit board with the display facing downward.
  14. LG CG180 Display Replacement: adım 14, 1 resimden 1.
    • Use thumb to release both white clips at the top of the circuit board.
    • Be careful with the display because it is still attached by electrical tape.
  15. LG CG180 Display Replacement: adım 15, 2 resimden 1. LG CG180 Display Replacement: adım 15, 2 resimden 2.
    • Once both clips are released, turn over the circuit board so that the display is facing upward.
    • Carefully lift the display from the left side and open to the right.
  16. LG CG180 Display Replacement: adım 16, 1 resimden 1.
    • Carefully remove the electrical tape from the display.
  17. LG CG180 Display Replacement: adım 17, 1 resimden 1.
    • The display is disconnected from the circuit board.
Sonuç
Alex Jacobs
5 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-42, Regan Winter 2010 Cal Poly, Team 14-42, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G42
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,851
