Ana içeriğe geç
LG CG180 Display Replacement
Neye ihtiyacın var
    1. LG CG180 Display Replacement, Battery: adım 1, 1 resimden 1.
      • Power down the cell phone by pressing and holding down the red "end call" button.
      FixBot'a Sor
      Yorum Ekle
    2. LG CG180 Display Replacement: adım 2, 1 resimden 1.
      • Turn the phone screen-down so you are looking at the back cover.
      FixBot'a Sor
      Yorum Ekle
    3. LG CG180 Display Replacement: adım 3, 2 resimden 1. LG CG180 Display Replacement: adım 3, 2 resimden 2.
      • Slide the back cover down using your finger to remove the cover from the phone.
      FixBot'a Sor
      Yorum Ekle
    4. LG CG180 Display Replacement: adım 4, 1 resimden 1.
      • Place your finger at the top of the battery in small gap.
      FixBot'a Sor
      Yorum Ekle
    5. LG CG180 Display Replacement: adım 5, 1 resimden 1.
      • Press downward while pulling outward to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG CG180 Display Replacement, Hardshell Case: adım 6, 1 resimden 1.
      • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. LG CG180 Display Replacement: adım 7, 1 resimden 1.
      • Insert a plastic opening tool in the seam.
      FixBot'a Sor
      Yorum Ekle
    3. LG CG180 Display Replacement: adım 8, 2 resimden 1. LG CG180 Display Replacement: adım 8, 2 resimden 2.
      • Run the tool along the seam to release all the tabs.
      FixBot'a Sor
      Yorum Ekle
    4. LG CG180 Display Replacement: adım 9, 2 resimden 1. LG CG180 Display Replacement: adım 9, 2 resimden 2.
      • Pull the phone back cover off once all the tabs are released.
      FixBot'a Sor
      Yorum Ekle
    5. LG CG180 Display Replacement: adım 10, 1 resimden 1.
      • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
      FixBot'a Sor
      Yorum Ekle
    6. LG CG180 Display Replacement: adım 11, 1 resimden 1.
      • The hardshell case is separated from the rest of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG CG180 Display Replacement, Keypad: adım 12, 2 resimden 1. LG CG180 Display Replacement, Keypad: adım 12, 2 resimden 2.
      • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
      FixBot'a Sor
      Yorum Ekle
    1. LG CG180 Display Replacement, Display: adım 13, 1 resimden 1.
      • Place the circuit board with the display facing downward.
      FixBot'a Sor
      Yorum Ekle
    2. LG CG180 Display Replacement: adım 14, 1 resimden 1.
      • Use thumb to release both white clips at the top of the circuit board.
      • Be careful with the display because it is still attached by electrical tape.
      FixBot'a Sor
      Yorum Ekle
    3. LG CG180 Display Replacement: adım 15, 2 resimden 1. LG CG180 Display Replacement: adım 15, 2 resimden 2.
      • Once both clips are released, turn over the circuit board so that the display is facing upward.
      • Carefully lift the display from the left side and open to the right.
      FixBot'a Sor
      Yorum Ekle
    4. LG CG180 Display Replacement: adım 16, 1 resimden 1.
      • Carefully remove the electrical tape from the display.
      FixBot'a Sor
      Yorum Ekle
    5. LG CG180 Display Replacement: adım 17, 1 resimden 1.
      • The display is disconnected from the circuit board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Alex Jacobs
17 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-42, Regan Winter 2010 Cal Poly, Team 14-42, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G42
4 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 2,083
