Ana içeriğe geç
LG CG180 Hardshell Case Replacement
Neye ihtiyacın var
  1. LG CG180 Hardshell Case Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Hardshell Case Replacement: adım 2, 1 resimden 1.
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Hardshell Case Replacement: adım 3, 2 resimden 1. LG CG180 Hardshell Case Replacement: adım 3, 2 resimden 2.
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Hardshell Case Replacement: adım 4, 1 resimden 1.
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Hardshell Case Replacement: adım 5, 1 resimden 1.
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Hardshell Case Replacement, Hardshell Case: adım 6, 1 resimden 1.
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Hardshell Case Replacement: adım 7, 1 resimden 1.
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Hardshell Case Replacement: adım 8, 2 resimden 1. LG CG180 Hardshell Case Replacement: adım 8, 2 resimden 2.
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Hardshell Case Replacement: adım 9, 2 resimden 1. LG CG180 Hardshell Case Replacement: adım 9, 2 resimden 2.
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Hardshell Case Replacement: adım 10, 1 resimden 1.
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Hardshell Case Replacement: adım 11, 1 resimden 1.
    • The hardshell case is separated from the rest of the phone.
Sonuç
Justin Helmer
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-42, Regan Winter 2010 Cal Poly, Team 14-42, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G42
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 1,810
