Ana içeriğe geç
LG CG225 Keyboard Replacement
Neye ihtiyacın var
  1. LG CG225 Keyboard Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Keyboard Replacement: adım 3, 1 resimden 1.
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Keyboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Keyboard Replacement: adım 5, 1 resimden 1.
    • Using a small plastic opening tool, remove the motherboard.
  6. LG CG225 Keyboard Replacement, Keyboard: adım 6, 1 resimden 1.
    • Using your fingers, remove the plastic keyboard.
    • Loose buttons will sometimes fall off of the keyboard when it is removed.
Sonuç
Mackenzie
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-3, Meza Spring 2014 Ohio State, Team 1-3, Meza Spring 2014 üyesi
OSU-MEZA-S14S1G3
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 359
