Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
Remove a single Phillips #00 screw from beneath the cover.
Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
Using a small plastic opening tool, remove the motherboard.
