Ana içeriğe geç
LG CG225 Motherboard Replacement
Neye ihtiyacın var
  1. LG CG225 Motherboard Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Motherboard Replacement: adım 3, 1 resimden 1.
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a small plastic opening tool, remove the motherboard.
Sonuç
Darlena
219 İtibar
3 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 üyesi
OSU-BUEHL-S14S1G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 173
