Ana içeriğe geç
LG CU515 Keypad Replacement
Neye ihtiyacın var
    1. LG CU515 Keypad Replacement, Battery: adım 1, 2 resimden 1. LG CU515 Keypad Replacement, Battery: adım 1, 2 resimden 2.
      • Use your thumb to press down and slide off the back cover of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG CU515 Keypad Replacement: adım 2, 3 resimden 1. LG CU515 Keypad Replacement: adım 2, 3 resimden 2. LG CU515 Keypad Replacement: adım 2, 3 resimden 3.
      • Take out the battery by levering it out towards the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG CU515 Keypad Replacement, Motherboard: adım 3, 1 resimden 1.
      • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
      FixBot'a Sor
      Yorum Ekle
    2. LG CU515 Keypad Replacement: adım 4, 1 resimden 1.
      • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. LG CU515 Keypad Replacement: adım 5, 3 resimden 1. LG CU515 Keypad Replacement: adım 5, 3 resimden 2. LG CU515 Keypad Replacement: adım 5, 3 resimden 3.
      • Push the spudger into the crack separating the two pieces of the phone.
      • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
      • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
      • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
      FixBot'a Sor
      Yorum Ekle
    4. LG CU515 Keypad Replacement: adım 6, 1 resimden 1.
      • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. LG CU515 Keypad Replacement: adım 7, 1 resimden 1.
      • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
      FixBot'a Sor
      Yorum Ekle
    6. LG CU515 Keypad Replacement: adım 8, 1 resimden 1.
      • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
      • Replace the motherboard with a new one.
      FixBot'a Sor
      Yorum Ekle
    1. LG CU515 Keypad Replacement, Keypad: adım 9, 1 resimden 1.
      • Push keypad up and out of the phone casing until they separate.
      • Replace with new keypad.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Zack Mintzer
1 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-55, Johann Spring 2013 Cal Poly, Team 21-55, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G55
4 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 32
Her zaman: 538
