Giriş
Restore sound to your phone by replacng the speaker.
Neye ihtiyacın var
Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
Push the spudger into the crack separating the two pieces of the phone.
Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
Remove the speaker component from the back of the phone by lifting up the top part to a 45 degree angle and pulling it out.
