Ana içeriğe geç
LG CU515 Speaker Replacement
Neye ihtiyacın var
  1. LG CU515 Speaker Replacement, Battery: adım 1, 2 resimden 1. LG CU515 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Speaker Replacement: adım 2, 3 resimden 1. LG CU515 Speaker Replacement: adım 2, 3 resimden 2. LG CU515 Speaker Replacement: adım 2, 3 resimden 3.
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Speaker Replacement, Motherboard: adım 3, 1 resimden 1.
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Speaker Replacement: adım 4, 1 resimden 1.
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Speaker Replacement: adım 5, 3 resimden 1. LG CU515 Speaker Replacement: adım 5, 3 resimden 2. LG CU515 Speaker Replacement: adım 5, 3 resimden 3.
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Speaker Replacement: adım 6, 1 resimden 1.
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Speaker Replacement: adım 8, 1 resimden 1.
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
  9. LG CU515 Speaker Replacement, Speaker: adım 9, 2 resimden 1. LG CU515 Speaker Replacement, Speaker: adım 9, 2 resimden 2.
    • Remove the speaker component from the back of the phone by lifting up the top part to a 45 degree angle and pulling it out.
  10. LG CU515 Speaker Replacement: adım 10, 1 resimden 1.
    • Pull speaker out of the component by grabbing the wire attached to it in order to replace it.
Sonuç
Zack Mintzer
1 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-55, Johann Spring 2013 Cal Poly, Team 21-55, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G55
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 392
