Ana içeriğe geç
LG Chocolate 3 Front Faceplate Replacement
Neye ihtiyacın var
    1. LG Chocolate 3 Front Faceplate Replacement, Front Faceplate: adım 1, 1 resimden 1.
      • Use the plastic opening tool to lift the front faceplate from the device.
      • The faceplate has adhesive in multiple areas. Loosen the faceplate around all of the edges first to make it easier to remove.
      FixBot'a Sor
      Yorum Ekle
    2. LG Chocolate 3 Front Faceplate Replacement: adım 2, 1 resimden 1.
      • The scroll wheel has an orange display data cable attached which may rip from excessive force.
      • Lift the front faceplate up gently.
      FixBot'a Sor
      Yorum Ekle
    3. LG Chocolate 3 Front Faceplate Replacement: adım 3, 1 resimden 1.
      • Be careful not to rip the orange display data cable or drop the scroll wheel on the LCD screen.
      • Use the flat end of the spudger to pry the scroll wheel from the faceplate.
      FixBot'a Sor
      Yorum Ekle
    4. LG Chocolate 3 Front Faceplate Replacement: adım 4, 2 resimden 1. LG Chocolate 3 Front Faceplate Replacement: adım 4, 2 resimden 2.
      • Separate the front faceplate from the device completely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brenna Yagade
40 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G35
5 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 559
