Ana içeriğe geç
LG Chocolate 3 Front Faceplate Replacement
Neye ihtiyacın var
  1. LG Chocolate 3 Front Faceplate Replacement, Front Faceplate: adım 1, 1 resimden 1.
    • Use the plastic opening tool to lift the front faceplate from the device.
    • The faceplate has adhesive in multiple areas. Loosen the faceplate around all of the edges first to make it easier to remove.
  2. LG Chocolate 3 Front Faceplate Replacement: adım 2, 1 resimden 1.
    • The scroll wheel has an orange display data cable attached which may rip from excessive force.
    • Lift the front faceplate up gently.
  3. LG Chocolate 3 Front Faceplate Replacement: adım 3, 1 resimden 1.
    • Be careful not to rip the orange display data cable or drop the scroll wheel on the LCD screen.
    • Use the flat end of the spudger to pry the scroll wheel from the faceplate.
  4. LG Chocolate 3 Front Faceplate Replacement: adım 4, 2 resimden 1. LG Chocolate 3 Front Faceplate Replacement: adım 4, 2 resimden 2.
    • Separate the front faceplate from the device completely.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brenna Yagade
40 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G35
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 292
