Ana içeriğe geç
LG Chocolate 3 Keypad Replacement
Neye ihtiyacın var
  1. LG Chocolate 3 Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
  2. LG Chocolate 3 Keypad Replacement: adım 2, 3 resimden 1. LG Chocolate 3 Keypad Replacement: adım 2, 3 resimden 2. LG Chocolate 3 Keypad Replacement: adım 2, 3 resimden 3.
    • Using your index finger lift and remove the battery from the phone.
  3. LG Chocolate 3 Keypad Replacement, Rear Case: adım 3, 1 resimden 1.
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
  4. LG Chocolate 3 Keypad Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
  5. LG Chocolate 3 Keypad Replacement: adım 5, 2 resimden 1. LG Chocolate 3 Keypad Replacement: adım 5, 2 resimden 2.
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
  6. LG Chocolate 3 Keypad Replacement: adım 6, 1 resimden 1.
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
  7. LG Chocolate 3 Keypad Replacement: adım 7, 2 resimden 1. LG Chocolate 3 Keypad Replacement: adım 7, 2 resimden 2.
    • Carefully remove the rear case from the phone.
  8. LG Chocolate 3 Keypad Replacement, Side Buttons: adım 8, 1 resimden 1.
    Satın Al
    • Use tweezers to remove the music button found on the side of the phone.
  9. LG Chocolate 3 Keypad Replacement: adım 9, 2 resimden 1. LG Chocolate 3 Keypad Replacement: adım 9, 2 resimden 2.
    • Use tweezers to remove the volume control buttons on the opposite side of the phone.
  10. LG Chocolate 3 Keypad Replacement, Motherboard: adım 10, 1 resimden 1.
    • Use the flat end of the spudger to lift the orange display data cable.
  11. LG Chocolate 3 Keypad Replacement: adım 11, 2 resimden 1. LG Chocolate 3 Keypad Replacement: adım 11, 2 resimden 2.
    • Carefully insert the plastic opening tool between the motherboard and the back of the phone.
  12. LG Chocolate 3 Keypad Replacement: adım 12, 2 resimden 1. LG Chocolate 3 Keypad Replacement: adım 12, 2 resimden 2.
    • Use your thumb and index finger to carefully lift and separate the motherboard from the back of the phone.
    • Be cautious of the orange display data cable, it may stick to the motherboard.
    • To avoid this, lift the data cable away from the motherboard before removal.
  13. LG Chocolate 3 Keypad Replacement, Keypad: adım 13, 1 resimden 1.
    • Open the phone.
    • Keep the phone open by keeping a firm grip on the hinges to avoid any damages to the phone.
  14. LG Chocolate 3 Keypad Replacement: adım 14, 1 resimden 1.
    • Lift the orange data cable up so that it is elevated.
    • Gently use a finger to lift the keypad out.
  15. LG Chocolate 3 Keypad Replacement: adım 15, 1 resimden 1.
    • Insert the spudger in between the keypad and the phone.
    • Lift the keypad to seperate it from the phone.
  16. LG Chocolate 3 Keypad Replacement: adım 16, 2 resimden 1. LG Chocolate 3 Keypad Replacement: adım 16, 2 resimden 2.
    • Remove the damaged keypad.
    • Insert the replacement keypad.
    • Reassemble the phone after the broken keypad is replaced.
Sonuç
To reassemble this device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Brenna Yagade
40 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G35
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 530
