Ana içeriğe geç
LG Chocolate 3 Side Buttons Replacement
Neye ihtiyacın var
  1. LG Chocolate 3 Side Buttons Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
  2. LG Chocolate 3 Side Buttons Replacement: adım 2, 3 resimden 1. LG Chocolate 3 Side Buttons Replacement: adım 2, 3 resimden 2. LG Chocolate 3 Side Buttons Replacement: adım 2, 3 resimden 3.
    • Using your index finger lift and remove the battery from the phone.
  3. LG Chocolate 3 Side Buttons Replacement, Rear Case: adım 3, 1 resimden 1.
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
  4. LG Chocolate 3 Side Buttons Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
  5. LG Chocolate 3 Side Buttons Replacement: adım 5, 2 resimden 1. LG Chocolate 3 Side Buttons Replacement: adım 5, 2 resimden 2.
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
  6. LG Chocolate 3 Side Buttons Replacement: adım 6, 1 resimden 1.
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
  7. LG Chocolate 3 Side Buttons Replacement: adım 7, 2 resimden 1. LG Chocolate 3 Side Buttons Replacement: adım 7, 2 resimden 2.
    • Carefully remove the rear case from the phone.
  8. LG Chocolate 3 Side Buttons Replacement, Side Buttons: adım 8, 1 resimden 1.
    • Use tweezers to remove the music button found on the side of the phone.
  9. LG Chocolate 3 Side Buttons Replacement: adım 9, 2 resimden 1. LG Chocolate 3 Side Buttons Replacement: adım 9, 2 resimden 2.
    • Use tweezers to remove the volume control buttons on the opposite side of the phone.
Sonuç
Brenna Yagade
40 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G35
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 226
