Ana içeriğe geç
LG Chocolate Keypad Replacement
Neye ihtiyacın var
    1. LG Chocolate Keypad Replacement, Battery: adım 1, 2 resimden 1. LG Chocolate Keypad Replacement, Battery: adım 1, 2 resimden 2.
      • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
      • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
      FixBot'a Sor
      Yorum Ekle
    1. LG Chocolate Keypad Replacement, Back Cover: adım 2, 1 resimden 1.
      • You will need to use a Phillips #00 screwdriver.
      • Remove the four screws located at the corners beneath the battery.
      • Detach the back case from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG Chocolate Keypad Replacement: adım 3, 3 resimden 1. LG Chocolate Keypad Replacement: adım 3, 3 resimden 2. LG Chocolate Keypad Replacement: adım 3, 3 resimden 3.
      • Take the case off by using a plastic opening tool.
      • Continue using the plastic opening tool around the sides of the device.
      • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
      • The back speaker will be connected to the motherboard.
      • This must be disconnected in order to remove the case.
      FixBot'a Sor
      Yorum Ekle
    1. LG Chocolate Keypad Replacement, Sliding Front: adım 4, 1 resimden 1.
      • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
      FixBot'a Sor
      Yorum Ekle
    2. LG Chocolate Keypad Replacement: adım 5, 2 resimden 1. LG Chocolate Keypad Replacement: adım 5, 2 resimden 2.
      • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
      FixBot'a Sor
      Yorum Ekle
    3. LG Chocolate Keypad Replacement: adım 6, 2 resimden 1. LG Chocolate Keypad Replacement: adım 6, 2 resimden 2.
      • Pry off the plastic tabs that cover two screws, as shown in the first picture.
      • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
      FixBot'a Sor
      Yorum Ekle
    4. LG Chocolate Keypad Replacement: adım 7, 1 resimden 1.
      • Pry off the back cover from the front of the case using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. LG Chocolate Keypad Replacement, LCD Board: adım 8, 3 resimden 1. LG Chocolate Keypad Replacement, LCD Board: adım 8, 3 resimden 2. LG Chocolate Keypad Replacement, LCD Board: adım 8, 3 resimden 3.
      • Pry the front speaker and wireless receiver out of the front case using a spudger.
      • They may be taped into the case, so don't be afraid to pry hard.
      FixBot'a Sor
      Yorum Ekle
    2. LG Chocolate Keypad Replacement: adım 9, 2 resimden 1. LG Chocolate Keypad Replacement: adım 9, 2 resimden 2.
      • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
      FixBot'a Sor
      Yorum Ekle
    3. LG Chocolate Keypad Replacement: adım 10, 1 resimden 1.
      • Unhook the ribbon cable using that flat side of a spudger.
      FixBot'a Sor
      Yorum Ekle
    4. LG Chocolate Keypad Replacement: adım 11, 1 resimden 1.
      • Next, carefully remove the tape from the LCD board.
      FixBot'a Sor
      Yorum Ekle
    5. LG Chocolate Keypad Replacement: adım 12, 2 resimden 1. LG Chocolate Keypad Replacement: adım 12, 2 resimden 2.
      • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
      • The LCD Board in now accessible.
      FixBot'a Sor
      Yorum Ekle
    1. LG Chocolate Keypad Replacement, LCD Screen: adım 13, 1 resimden 1.
      • The LCD screen is no longer connected to the LCD board.
      FixBot'a Sor
      Yorum Ekle
    1. LG Chocolate Keypad Replacement, Keypad: adım 14, 1 resimden 1.
      • Push the keypad out from the front of the phone and remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Maci Miri
39 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G46
4 Üyeler
132 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 691
