Ana içeriğe geç
LG Chocolate Sliding Front Replacement
Neye ihtiyacın var
  1. LG Chocolate Sliding Front Replacement, Battery: adım 1, 2 resimden 1. LG Chocolate Sliding Front Replacement, Battery: adım 1, 2 resimden 2.
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Sliding Front Replacement, Back Cover: adım 2, 1 resimden 1.
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Sliding Front Replacement: adım 3, 3 resimden 1. LG Chocolate Sliding Front Replacement: adım 3, 3 resimden 2. LG Chocolate Sliding Front Replacement: adım 3, 3 resimden 3.
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
  4. LG Chocolate Sliding Front Replacement, Sliding Front: adım 4, 1 resimden 1.
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Sliding Front Replacement: adım 5, 2 resimden 1. LG Chocolate Sliding Front Replacement: adım 5, 2 resimden 2.
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Sliding Front Replacement: adım 6, 2 resimden 1. LG Chocolate Sliding Front Replacement: adım 6, 2 resimden 2.
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Sliding Front Replacement: adım 7, 1 resimden 1.
    • Pry off the back cover from the front of the case using a plastic opening tool.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maci Miri
39 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G46
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 411
