Ana içeriğe geç
LG Chocolate Sliding Mechanism Replacement
Neye ihtiyacın var
  1. LG Chocolate Sliding Mechanism Replacement, Battery: adım 1, 2 resimden 1. LG Chocolate Sliding Mechanism Replacement, Battery: adım 1, 2 resimden 2.
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Sliding Mechanism Replacement, Back Cover: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Sliding Mechanism Replacement: adım 3, 3 resimden 1. LG Chocolate Sliding Mechanism Replacement: adım 3, 3 resimden 2. LG Chocolate Sliding Mechanism Replacement: adım 3, 3 resimden 3.
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Sliding Mechanism Replacement, Sliding Front: adım 4, 1 resimden 1.
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Sliding Mechanism Replacement: adım 5, 2 resimden 1. LG Chocolate Sliding Mechanism Replacement: adım 5, 2 resimden 2.
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Sliding Mechanism Replacement: adım 6, 2 resimden 1. LG Chocolate Sliding Mechanism Replacement: adım 6, 2 resimden 2.
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Sliding Mechanism Replacement: adım 7, 1 resimden 1.
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Sliding Mechanism Replacement, Sliding Mechanism: adım 8, 1 resimden 1.
    • Use a Phillips #00 to remove the 4 screws that hold the sliding mechanism in place.
  9. LG Chocolate Sliding Mechanism Replacement: adım 9, 1 resimden 1.
    • Remove sliding mechanism.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Thomas
91 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G46
4 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 373
