Ana içeriğe geç
LG Chocolate Touch Buttons Replacement
Neye ihtiyacın var
  1. LG Chocolate Touch Buttons Replacement, Battery: adım 1, 2 resimden 1. LG Chocolate Touch Buttons Replacement, Battery: adım 1, 2 resimden 2.
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Touch Buttons Replacement, Back Cover: adım 2, 1 resimden 1.
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Touch Buttons Replacement: adım 3, 3 resimden 1. LG Chocolate Touch Buttons Replacement: adım 3, 3 resimden 2. LG Chocolate Touch Buttons Replacement: adım 3, 3 resimden 3.
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate Touch Buttons Replacement, Sliding Front: adım 4, 1 resimden 1.
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Touch Buttons Replacement: adım 5, 2 resimden 1. LG Chocolate Touch Buttons Replacement: adım 5, 2 resimden 2.
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Touch Buttons Replacement: adım 6, 2 resimden 1. LG Chocolate Touch Buttons Replacement: adım 6, 2 resimden 2.
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Touch Buttons Replacement: adım 7, 1 resimden 1.
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Touch Buttons Replacement, LCD Board: adım 8, 3 resimden 1. LG Chocolate Touch Buttons Replacement, LCD Board: adım 8, 3 resimden 2. LG Chocolate Touch Buttons Replacement, LCD Board: adım 8, 3 resimden 3.
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Touch Buttons Replacement: adım 9, 2 resimden 1. LG Chocolate Touch Buttons Replacement: adım 9, 2 resimden 2.
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Touch Buttons Replacement: adım 10, 1 resimden 1.
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Touch Buttons Replacement: adım 11, 1 resimden 1.
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Touch Buttons Replacement: adım 12, 2 resimden 1. LG Chocolate Touch Buttons Replacement: adım 12, 2 resimden 2.
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Touch Buttons Replacement, Touch Buttons: adım 13, 1 resimden 1.
    • Using a flat head screwdriver, pry the plastic covering off of the back of the keypad
  14. LG Chocolate Touch Buttons Replacement: adım 14, 2 resimden 1. LG Chocolate Touch Buttons Replacement: adım 14, 2 resimden 2.
    • Push the keypad from behind to disconnect it from the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Thomas
91 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G46
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 430
