Ana içeriğe geç
LG CineBeam Lens Replacement
Neye ihtiyacın var
  1. LG CineBeam Lens Replacement, Bottom Plate: adım 1, 1 resimden 1.
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. LG CineBeam Lens Replacement: adım 2, 3 resimden 1. LG CineBeam Lens Replacement: adım 2, 3 resimden 2. LG CineBeam Lens Replacement: adım 2, 3 resimden 3.
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
    FixBot'a Sor
    Yorum Ekle
  3. LG CineBeam Lens Replacement, Motherboard: adım 3, 3 resimden 1. LG CineBeam Lens Replacement, Motherboard: adım 3, 3 resimden 2. LG CineBeam Lens Replacement, Motherboard: adım 3, 3 resimden 3.
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
    FixBot'a Sor
    Yorum Ekle
  4. LG CineBeam Lens Replacement: adım 4, 2 resimden 1. LG CineBeam Lens Replacement: adım 4, 2 resimden 2.
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
    FixBot'a Sor
    Yorum Ekle
  5. LG CineBeam Lens Replacement: adım 5, 3 resimden 1. LG CineBeam Lens Replacement: adım 5, 3 resimden 2. LG CineBeam Lens Replacement: adım 5, 3 resimden 3.
    • Lift the motherboard out of the casing.
    FixBot'a Sor
    Yorum Ekle
  6. LG CineBeam Lens Replacement, Speaker: adım 6, 2 resimden 1. LG CineBeam Lens Replacement, Speaker: adım 6, 2 resimden 2.
    • Use your fingers to lift the speaker from the casing.
    FixBot'a Sor
    Yorum Ekle
  7. LG CineBeam Lens Replacement, Lens: adım 7, 3 resimden 1. LG CineBeam Lens Replacement, Lens: adım 7, 3 resimden 2. LG CineBeam Lens Replacement, Lens: adım 7, 3 resimden 3.
    • Turn the device over so the power button is facing up.
    • Using an iFixit opening tool, pry open the top of the plastic casing and remove it completely.
    FixBot'a Sor
    Yorum Ekle
  8. LG CineBeam Lens Replacement: adım 8, 2 resimden 1. LG CineBeam Lens Replacement: adım 8, 2 resimden 2.
    • Remove the three 6 mm screws holding the lens and LCoS assembly in place using a Phillips #00 screwdriver.
    • Remove the lens and LCoS assembly from the casing.
    FixBot'a Sor
    Yorum Ekle
  9. LG CineBeam Lens Replacement: adım 9, 3 resimden 1. LG CineBeam Lens Replacement: adım 9, 3 resimden 2. LG CineBeam Lens Replacement: adım 9, 3 resimden 3.
    • Remove the 4 mm screws using a Phillips #00 screwdriver.
    • Pull the lens assembly off of the display assembly.
    • When putting in a new lens assembly, make sure the focus knob is on the correct side.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Abid Neron
243 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Botvin Spring 2022 UMass Dartmouth, Team 1-5, Botvin Spring 2022 üyesi
UMASSD-BOTVIN-S22S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 999
