Ana içeriğe geç
LG CineBeam Motherboard Replacement
Neye ihtiyacın var
  1. LG CineBeam Motherboard Replacement, Bottom Plate: adım 1, 1 resimden 1.
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. LG CineBeam Motherboard Replacement: adım 2, 3 resimden 1. LG CineBeam Motherboard Replacement: adım 2, 3 resimden 2. LG CineBeam Motherboard Replacement: adım 2, 3 resimden 3.
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
    FixBot'a Sor
    Yorum Ekle
  3. LG CineBeam Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. LG CineBeam Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. LG CineBeam Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
    FixBot'a Sor
    Yorum Ekle
  4. LG CineBeam Motherboard Replacement: adım 4, 2 resimden 1. LG CineBeam Motherboard Replacement: adım 4, 2 resimden 2.
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
    FixBot'a Sor
    Yorum Ekle
  5. LG CineBeam Motherboard Replacement: adım 5, 3 resimden 1. LG CineBeam Motherboard Replacement: adım 5, 3 resimden 2. LG CineBeam Motherboard Replacement: adım 5, 3 resimden 3.
    • Lift the motherboard out of the casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
John Dalton
393 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Botvin Spring 2022 UMass Dartmouth, Team 1-5, Botvin Spring 2022 üyesi
UMASSD-BOTVIN-S22S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 867
