Ana içeriğe geç
LG Cosmos 2 Front Keyboard Replacement
Neye ihtiyacın var
  1. LG Cosmos 2 Front Keyboard Replacement, Battery: adım 1, 3 resimden 1. LG Cosmos 2 Front Keyboard Replacement, Battery: adım 1, 3 resimden 2. LG Cosmos 2 Front Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Front Keyboard Replacement: adım 2, 3 resimden 1. LG Cosmos 2 Front Keyboard Replacement: adım 2, 3 resimden 2. LG Cosmos 2 Front Keyboard Replacement: adım 2, 3 resimden 3.
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Front Keyboard Replacement, Rear Case: adım 3, 1 resimden 1.
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Front Keyboard Replacement: adım 4, 3 resimden 1. LG Cosmos 2 Front Keyboard Replacement: adım 4, 3 resimden 2. LG Cosmos 2 Front Keyboard Replacement: adım 4, 3 resimden 3.
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Front Keyboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 Front Keyboard Replacement: adım 6, 1 resimden 1.
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 Front Keyboard Replacement: adım 7, 2 resimden 1. LG Cosmos 2 Front Keyboard Replacement: adım 7, 2 resimden 2.
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 Front Keyboard Replacement: adım 8, 2 resimden 1. LG Cosmos 2 Front Keyboard Replacement: adım 8, 2 resimden 2.
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 Front Keyboard Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 Front Keyboard Replacement, Option Buttons: adım 10, 1 resimden 1.
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  11. LG Cosmos 2 Front Keyboard Replacement: adım 11, 2 resimden 1. LG Cosmos 2 Front Keyboard Replacement: adım 11, 2 resimden 2.
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  12. LG Cosmos 2 Front Keyboard Replacement: adım 12, 1 resimden 1.
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  13. LG Cosmos 2 Front Keyboard Replacement: adım 13, 2 resimden 1. LG Cosmos 2 Front Keyboard Replacement: adım 13, 2 resimden 2.
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  14. LG Cosmos 2 Front Keyboard Replacement: adım 14, 1 resimden 1.
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  15. LG Cosmos 2 Front Keyboard Replacement: adım 15, 1 resimden 1.
    • Detach the ribbon cable with the plastic opener.
  16. LG Cosmos 2 Front Keyboard Replacement: adım 16, 3 resimden 1. LG Cosmos 2 Front Keyboard Replacement: adım 16, 3 resimden 2. LG Cosmos 2 Front Keyboard Replacement: adım 16, 3 resimden 3.
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  17. LG Cosmos 2 Front Keyboard Replacement: adım 17, 1 resimden 1.
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
  18. LG Cosmos 2 Front Keyboard Replacement, Front Keyboard: adım 18, 2 resimden 1. LG Cosmos 2 Front Keyboard Replacement, Front Keyboard: adım 18, 2 resimden 2.
    • Use a tool to pry open the LCD display. Remove the display and the motherboard-looking device that it's connected to.
  19. LG Cosmos 2 Front Keyboard Replacement: adım 19, 1 resimden 1.
    • Rotate and remove the keypad from the front case.
Sonuç
Nick White
851 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-1, Benson Fall 2013 Clemson, Team 13-1, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G1
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 669
