Ana içeriğe geç
LG Cosmos 2 QWERTY Keyboard Replacement
Neye ihtiyacın var
    1. LG Cosmos 2 QWERTY Keyboard Replacement, Battery: adım 1, 3 resimden 1. LG Cosmos 2 QWERTY Keyboard Replacement, Battery: adım 1, 3 resimden 2. LG Cosmos 2 QWERTY Keyboard Replacement, Battery: adım 1, 3 resimden 3.
      • Insert the plastic opener into the slot at the top of the device.
      • Apply gentle pressure with the plastic tool to pop the back case off.
      FixBot'a Sor
      Yorum Ekle
    2. LG Cosmos 2 QWERTY Keyboard Replacement: adım 2, 3 resimden 1. LG Cosmos 2 QWERTY Keyboard Replacement: adım 2, 3 resimden 2. LG Cosmos 2 QWERTY Keyboard Replacement: adım 2, 3 resimden 3.
      • Use the plastic opener to lift, and remove, the device battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG Cosmos 2 QWERTY Keyboard Replacement, Rear Case: adım 3, 1 resimden 1.
      • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
      FixBot'a Sor
      Yorum Ekle
    2. LG Cosmos 2 QWERTY Keyboard Replacement: adım 4, 3 resimden 1. LG Cosmos 2 QWERTY Keyboard Replacement: adım 4, 3 resimden 2. LG Cosmos 2 QWERTY Keyboard Replacement: adım 4, 3 resimden 3.
      • Use the plastic opener to pry the rear case loose.
      • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
      FixBot'a Sor
      Yorum Ekle
    1. LG Cosmos 2 QWERTY Keyboard Replacement, Motherboard: adım 5, 1 resimden 1.
      • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
      FixBot'a Sor
      Yorum Ekle
    2. LG Cosmos 2 QWERTY Keyboard Replacement: adım 6, 1 resimden 1.
      • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    3. LG Cosmos 2 QWERTY Keyboard Replacement: adım 7, 2 resimden 1. LG Cosmos 2 QWERTY Keyboard Replacement: adım 7, 2 resimden 2.
      • Use the plastic opener to disconnect the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. LG Cosmos 2 QWERTY Keyboard Replacement: adım 8, 2 resimden 1. LG Cosmos 2 QWERTY Keyboard Replacement: adım 8, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use tweezers to disconnect the two cables that attach the motherboard to the case.
      • Note: Pull on the cables gently to prevent damage for future use.
      FixBot'a Sor
      Yorum Ekle
    5. LG Cosmos 2 QWERTY Keyboard Replacement: adım 9, 1 resimden 1.
      • Remove the motherboard from the front case.
      FixBot'a Sor
      Yorum Ekle
    1. LG Cosmos 2 QWERTY Keyboard Replacement, QWERTY Keyboard: adım 10, 1 resimden 1.
      • Flip the front case over. If the keyboard doesn't fall out, push it through the front case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick White
866 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-1, Benson Fall 2013 Clemson, Team 13-1, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G1
3 Üyeler
80 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 861
