Ana içeriğe geç
LG Cosmos 2 Speaker Replacement
Neye ihtiyacın var
  1. LG Cosmos 2 Speaker Replacement, Battery: adım 1, 3 resimden 1. LG Cosmos 2 Speaker Replacement, Battery: adım 1, 3 resimden 2. LG Cosmos 2 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Speaker Replacement: adım 2, 3 resimden 1. LG Cosmos 2 Speaker Replacement: adım 2, 3 resimden 2. LG Cosmos 2 Speaker Replacement: adım 2, 3 resimden 3.
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Speaker Replacement, Rear Case: adım 3, 1 resimden 1.
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Speaker Replacement: adım 4, 3 resimden 1. LG Cosmos 2 Speaker Replacement: adım 4, 3 resimden 2. LG Cosmos 2 Speaker Replacement: adım 4, 3 resimden 3.
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Speaker Replacement, Speaker: adım 5, 2 resimden 1. LG Cosmos 2 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
Sonuç
Nick White
866 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-1, Benson Fall 2013 Clemson, Team 13-1, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G1
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 391
