Ana içeriğe geç
LG Cosmos Silicon Keypad Replacement
Neye ihtiyacın var
    1. LG Cosmos Silicon Keypad Replacement, Battery: adım 1, 1 resimden 1.
      • Apply an upward force to slide the back cover off.
      FixBot'a Sor
      Yorum Ekle
    2. LG Cosmos Silicon Keypad Replacement: adım 2, 1 resimden 1.
      • Use your finger to push down on the top of the battery and pull it out.
      FixBot'a Sor
      Yorum Ekle
    1. LG Cosmos Silicon Keypad Replacement, Rear Case: adım 3, 1 resimden 1.
      • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
      FixBot'a Sor
      Yorum Ekle
    2. LG Cosmos Silicon Keypad Replacement: adım 4, 1 resimden 1.
      • Use a plastic opening tool to pry the rear case loose.
      FixBot'a Sor
      Yorum Ekle
    3. LG Cosmos Silicon Keypad Replacement: adım 5, 1 resimden 1.
      • Once the rear case is loose, lift it from the rest of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG Cosmos Silicon Keypad Replacement, Motherboard: adım 6, 1 resimden 1.
      • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
      FixBot'a Sor
      Yorum Ekle
    2. LG Cosmos Silicon Keypad Replacement: adım 7, 1 resimden 1.
      • Use the plastic opening tool to pry the motherboard loose.
      FixBot'a Sor
      Yorum Ekle
    3. LG Cosmos Silicon Keypad Replacement: adım 8, 1 resimden 1.
      • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
      • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
      FixBot'a Sor
      Yorum Ekle
    4. LG Cosmos Silicon Keypad Replacement: adım 9, 1 resimden 1.
      • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
      FixBot'a Sor
      Yorum Ekle
    5. LG Cosmos Silicon Keypad Replacement: adım 10, 1 resimden 1.
      • Use your finger to pull the flex cable out from its connector.
      FixBot'a Sor
      Yorum Ekle
    6. LG Cosmos Silicon Keypad Replacement: adım 11, 1 resimden 1.
      • Pull the motherboard away from the rest of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG Cosmos Silicon Keypad Replacement, Silicon Keypad: adım 12, 1 resimden 1.
      • Lift the silicon keypad away from the rest of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Johnny Phane
91 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-63, Johann Spring 2013 Cal Poly, Team 13-63, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G63
3 Üyeler
50 adet Kılavuz yazıldı
1Rehber Yorum
Steps 10 and 11 are not necessary for replacing just the silicone keypad. As long as you are careful not to pull on the motherboard, once you have the motherboard rotated up, you are able to replace the silicone keypad directly from that point.
Randy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 1,212
