Giriş
If the QWERTY silicon keypad is worn out or damaged, it is replaceable. It requires time and a lot of disassembling.
Neye ihtiyacın var
Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
Bir başkası bu kılavuzu tamamladı.
