Ana içeriğe geç
LG Dare Digitizer Replacement
Neye ihtiyacın var
  1. LG Dare Digitizer Replacement, Battery: adım 1, 2 resimden 1. LG Dare Digitizer Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
  2. LG Dare Digitizer Replacement: adım 2, 3 resimden 1. LG Dare Digitizer Replacement: adım 2, 3 resimden 2. LG Dare Digitizer Replacement: adım 2, 3 resimden 3.
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
  3. LG Dare Digitizer Replacement, Logic Board: adım 3, 2 resimden 1. LG Dare Digitizer Replacement, Logic Board: adım 3, 2 resimden 2.
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
  4. LG Dare Digitizer Replacement: adım 4, 3 resimden 1. LG Dare Digitizer Replacement: adım 4, 3 resimden 2. LG Dare Digitizer Replacement: adım 4, 3 resimden 3.
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
  5. LG Dare Digitizer Replacement: adım 5, 3 resimden 1. LG Dare Digitizer Replacement: adım 5, 3 resimden 2. LG Dare Digitizer Replacement: adım 5, 3 resimden 3.
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
  6. LG Dare Digitizer Replacement: adım 6, 1 resimden 1.
    • Disconnect the three ribbon connectors from the motherboard.
  7. LG Dare Digitizer Replacement: adım 7, 3 resimden 1. LG Dare Digitizer Replacement: adım 7, 3 resimden 2. LG Dare Digitizer Replacement: adım 7, 3 resimden 3.
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
  8. LG Dare Digitizer Replacement: adım 8, 1 resimden 1.
    • Open the USB port cover.
  9. LG Dare Digitizer Replacement: adım 9, 3 resimden 1. LG Dare Digitizer Replacement: adım 9, 3 resimden 2. LG Dare Digitizer Replacement: adım 9, 3 resimden 3.
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
  10. LG Dare Digitizer Replacement, Earpiece: adım 10, 3 resimden 1. LG Dare Digitizer Replacement, Earpiece: adım 10, 3 resimden 2. LG Dare Digitizer Replacement, Earpiece: adım 10, 3 resimden 3.
    • Peel off the gold and green tape near the bottom of the phone.
    • Peel off the blue tape covering the speaker connector.
    • Peel off the gold tape to the left of the earpiece speaker.
    • It is unnecessary to remove the blue and gold tape from the device if the speaker is not being removed.
  11. LG Dare Digitizer Replacement: adım 11, 2 resimden 1. LG Dare Digitizer Replacement: adım 11, 2 resimden 2.
    • Lift up the orange ribbon cable in the bottom left corner of the device.
    • Peel off the small piece of gold tape underneath the orange component back.
  12. LG Dare Digitizer Replacement: adım 12, 2 resimden 1. LG Dare Digitizer Replacement: adım 12, 2 resimden 2.
    • Undo the clips that attach the black plastic strip to the frame of the phone.
    • Pry the plastic strip away from the phone, using an opening tool, until it detaches.
  13. LG Dare Digitizer Replacement: adım 13, 2 resimden 1. LG Dare Digitizer Replacement: adım 13, 2 resimden 2.
    • Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches.
  14. LG Dare Digitizer Replacement: adım 14, 2 resimden 1. LG Dare Digitizer Replacement: adım 14, 2 resimden 2.
    • Rotate the phone upside down with the back facing you.
    • Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
  15. LG Dare Digitizer Replacement: adım 15, 3 resimden 1. LG Dare Digitizer Replacement: adım 15, 3 resimden 2. LG Dare Digitizer Replacement: adım 15, 3 resimden 3.
    • Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around.
    • Do not detach the frame yet.
  16. LG Dare Digitizer Replacement: adım 16, 3 resimden 1. LG Dare Digitizer Replacement: adım 16, 3 resimden 2. LG Dare Digitizer Replacement: adım 16, 3 resimden 3.
    • Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture.
  17. LG Dare Digitizer Replacement: adım 17, 2 resimden 1. LG Dare Digitizer Replacement: adım 17, 2 resimden 2.
    • Remove both connectors from the frame. Fold back the L-shaped connector and slide the second connector through the hole in the metal frame.
    • Remove the frame from the plastic panel.
    • The next two steps are for earpiece removal only.
  18. LG Dare Digitizer Replacement: adım 18, 2 resimden 1. LG Dare Digitizer Replacement: adım 18, 2 resimden 2.
    • Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches.
    • It may be necessary to apply more force to remove the pad because it is taped to the frame.
  19. LG Dare Digitizer Replacement: adım 19, 2 resimden 1. LG Dare Digitizer Replacement: adım 19, 2 resimden 2.
    • Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece.
  20. LG Dare Digitizer Replacement, Screen: adım 20, 2 resimden 1. LG Dare Digitizer Replacement, Screen: adım 20, 2 resimden 2.
    • Lift all four corners of the screen.
    • Being too aggressive could damage the screen.
  21. LG Dare Digitizer Replacement: adım 21, 2 resimden 1. LG Dare Digitizer Replacement: adım 21, 2 resimden 2.
    • Remove the screen from the digitizer.
  22. LG Dare Digitizer Replacement, Digitizer: adım 22, 3 resimden 1. LG Dare Digitizer Replacement, Digitizer: adım 22, 3 resimden 2. LG Dare Digitizer Replacement, Digitizer: adım 22, 3 resimden 3.
    • Using the opening tool, carefully pry the digitizer (the black-rimmed piece) away from the silver frame.
    • Remove the digitizer carefully without breaking the connector.
    • Be careful when removing the digitizer because it is glued to the front panel. It may be necessary to apply more force or use a blow dryer to loosen the glue.
  23. LG Dare Digitizer Replacement: adım 23, 1 resimden 1.
    • Carefully remove the digitizer connector from the plastic frame. There is a slot that the connector slides through.
Sonuç
To re-assemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Haoyan Huang
139 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-4, Regan Winter 2012 Cal Poly, Team 9-4, Regan Winter 2012 üyesi
CPSU-REGAN-W12S9G4
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 5,195
