Ana içeriğe geç
LG Dare Logic Board Replacement
Neye ihtiyacın var
  1. LG Dare Logic Board Replacement, Battery: adım 1, 2 resimden 1. LG Dare Logic Board Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
  2. LG Dare Logic Board Replacement: adım 2, 3 resimden 1. LG Dare Logic Board Replacement: adım 2, 3 resimden 2. LG Dare Logic Board Replacement: adım 2, 3 resimden 3.
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
  3. LG Dare Logic Board Replacement, Logic Board: adım 3, 2 resimden 1. LG Dare Logic Board Replacement, Logic Board: adım 3, 2 resimden 2.
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
  4. LG Dare Logic Board Replacement: adım 4, 3 resimden 1. LG Dare Logic Board Replacement: adım 4, 3 resimden 2. LG Dare Logic Board Replacement: adım 4, 3 resimden 3.
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
  5. LG Dare Logic Board Replacement: adım 5, 3 resimden 1. LG Dare Logic Board Replacement: adım 5, 3 resimden 2. LG Dare Logic Board Replacement: adım 5, 3 resimden 3.
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
  6. LG Dare Logic Board Replacement: adım 6, 1 resimden 1.
    • Disconnect the three ribbon connectors from the motherboard.
  7. LG Dare Logic Board Replacement: adım 7, 3 resimden 1. LG Dare Logic Board Replacement: adım 7, 3 resimden 2. LG Dare Logic Board Replacement: adım 7, 3 resimden 3.
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
  8. LG Dare Logic Board Replacement: adım 8, 1 resimden 1.
    • Open the USB port cover.
  9. LG Dare Logic Board Replacement: adım 9, 3 resimden 1. LG Dare Logic Board Replacement: adım 9, 3 resimden 2. LG Dare Logic Board Replacement: adım 9, 3 resimden 3.
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
Sonuç
To re-assemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Haoyan Huang
151 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-4, Regan Winter 2012 Cal Poly, Team 9-4, Regan Winter 2012 üyesi
CPSU-REGAN-W12S9G4
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 20
Son 30 gün: 76
Her zaman: 2,472
