Ana içeriğe geç
LG EnV Touch VX11000 Keyboard Replacement
Neye ihtiyacın var
  1. LG EnV Touch VX11000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Keyboard Replacement: adım 3, 2 resimden 1. LG EnV Touch VX11000 Keyboard Replacement: adım 3, 2 resimden 2.
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Keyboard Replacement, Volume and Camera Buttons: adım 4, 2 resimden 1. LG EnV Touch VX11000 Keyboard Replacement, Volume and Camera Buttons: adım 4, 2 resimden 2.
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Keyboard Replacement: adım 5, 1 resimden 1.
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Keyboard Replacement: adım 6, 2 resimden 1. LG EnV Touch VX11000 Keyboard Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
    • Use your hands to open the phone, separating the keyboard frame from the screen.
    • Using your thumbs, gently separate the motherboard from the frame, and the keyboard will fall out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rachel Smith
593 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-2, Forte Fall 2013 Cal Poly, Team 13-2, Forte Fall 2013 üyesi
CPSU-FORTE-F13S13G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 462
