Ana içeriğe geç
LG EnV Touch VX11000 Screen Assembly Replacement
Neye ihtiyacın var
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Screen Assembly Replacement: adım 2, 1 resimden 1.
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Screen Assembly Replacement: adım 3, 2 resimden 1. LG EnV Touch VX11000 Screen Assembly Replacement: adım 3, 2 resimden 2.
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: adım 4, 2 resimden 1. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: adım 4, 2 resimden 2.
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Screen Assembly Replacement: adım 5, 1 resimden 1.
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Screen Assembly Replacement: adım 6, 2 resimden 1. LG EnV Touch VX11000 Screen Assembly Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: adım 7, 3 resimden 1. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: adım 7, 3 resimden 2. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: adım 7, 3 resimden 3.
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
  8. LG EnV Touch VX11000 Screen Assembly Replacement: adım 8, 2 resimden 1. LG EnV Touch VX11000 Screen Assembly Replacement: adım 8, 2 resimden 2.
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
  9. LG EnV Touch VX11000 Screen Assembly Replacement: adım 9, 2 resimden 1. LG EnV Touch VX11000 Screen Assembly Replacement: adım 9, 2 resimden 2.
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
  10. LG EnV Touch VX11000 Screen Assembly Replacement: adım 10, 1 resimden 1.
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
  11. LG EnV Touch VX11000 Screen Assembly Replacement: adım 11, 3 resimden 1. LG EnV Touch VX11000 Screen Assembly Replacement: adım 11, 3 resimden 2. LG EnV Touch VX11000 Screen Assembly Replacement: adım 11, 3 resimden 3.
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
  12. LG EnV Touch VX11000 Screen Assembly Replacement: adım 12, 2 resimden 1. LG EnV Touch VX11000 Screen Assembly Replacement: adım 12, 2 resimden 2.
    • Unplug the connector from the screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rachel Smith
593 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-2, Forte Fall 2013 Cal Poly, Team 13-2, Forte Fall 2013 üyesi
CPSU-FORTE-F13S13G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 1,189
