Giriş
If the camera button or the volume buttons on your LG EnV Touch VX11000 are jammed, stuck, or unresponsive, you may need to replace them. This guide will show you how to replace the camera and volume buttons on an LG EnV Touch VX11000.
Neye ihtiyacın var
Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
